another pi swap question
Old 02-25-2008, 03:20 PM
dbs96gt
dbs96gt's Avatar
Default another pi swap question
Does anyone know if you can use npi cams in the pi heads? i was thinking of using comp stage 2 npi's. Has anyone used these? What kinda power and sound can i expect?
dbs96gt is offline
Old 02-25-2008, 03:30 PM
Cassies01GT
Cassies01GT's Avatar
Default RE: another pi swap question
Where can I pick up a PI kit?
Cassies01GT is offline
Old 02-26-2008, 10:56 AM
edouglass77
edouglass77's Avatar
I'm sure the cams are interchangeable. A lot of people have said that just by changing out cams and intake manifold on an NPI with the PI cams and intake manifold you get all but about 10 of the HP increase you get from a full swap. I cannot say for sure that it's true, but that tells me the cams are interchangeable.
Hope that helps.
edouglass77 is offline
Old 02-26-2008, 12:21 PM
amoosenamedhank
amoosenamedhank's Avatar
I run an aftermarket npi cam in my pi heads.
amoosenamedhank is offline
Old 02-26-2008, 01:44 PM
Whamo
Whamo's Avatar
maby i dont know wtf im talking about but that really doesent even make sence... aftermarket npi cams...
can u link to these npi cams?
npi and pi is only a situational term if u will.
because they are interchangeable they are the same cam style and size. the only difference being the lope. as far as i know.
the ONLY npi cam is was came stock on the 4.6 untill 1999. anything else is gunna be a pi cam.
did that make sence? hmm... yeah i think it did.
Whamo is offline
04stangman
09-17-2015 01:45 PM
EASTIDEE123
09-14-2015 03:52 PM
jaiidutch
09-14-2015 10:29 AM
97SN95GT
09-13-2015 09:45 PM
Quick Reply: another pi swap question
