noise from transmission.. throwout bearing??
ok so i put a Spec stage 2 clutch in last weekend, and i've noticed an odd noise coming from under the car (just started today). i would describe it as sort of a chattering noise. when i start the car up and keep the clutch all the way to the floor, there's no noise, but as soon as i let the clutch out (tranny still in neutral) it starts making the noise. it also does it while i'm driving, but if i press on the clutch pedal then it stops. does this sound like a throwout bearing?? maybe a bearing on the input shaft inside the tranny???
RE: noise from transmission.. throwout bearing??
I would probably say throw-out bearing also.. the 3650 I had in the Mach before I modded it did that for about six months before it finally crapped itself at Kennedale.. Found out the shift-fork was broken too, but that chattering noise the way you describe it sounds like a bad TOB..
ORIGINAL: texas_stang02
ORIGINAL: lizzyfan
Did you tighten the pressure plate correctly?
ORIGINAL: kcp1989
please tell me you didnt use the pos spec throw out bearing
KingRando
10-02-2015 08:06 AM
ccdguy
09-19-2015 05:20 PM
