msd digital window switch
Ok so i have a zex dry kit and what not...thats all programed and wired up to go....now i have to tackle the window switch...im not sure exactly how it gets the nmu to activate or how to wire it...what i do no is
Black=ground
red= switched 12v(dont know where to tap into it)
there is a white wire,yellow and a grey wire....
i really need help putting this in cuz i have a dyno appt on tuesday march 11th nd i really need it done...so any help would be amazing...
thanks
Black=ground
thanks
RE: msd digital window switch
http://www.msdignition.com/1download.htm
Find it on this list and click on it.Hope this helps.
yes ive seen that before...but how does it tell the nitrous to activate? wouldnt it have to be connected to the nitrous management unit? and there still is the question about the yellow and grey wires...
white is your tach sensor wire, pull your passenger kick panel off and you will find the ecu. splice it into the green wire with the white stripe. will be pinn 26.
red wire i wired it in with my power switch for my nitrous. So when I turn on the nitrous the window switch turns on then.
Yellow wire i wired to the fuel pressure safety switch, then from the fuel pressure safety switch wired that to both the nitrous and fuel solenoids.
grey will not be used
