MAF to get or not to get??
Old 04-05-2005, 02:48 PM
DIVER8374
DIVER8374's Avatar
Default MAF to get or not to get??
I am wondering if I would benfit from getting a 80/85mm MAF with the mods that are listed in my sig, and have the Pro-chamber on order. If I will benfit from it which one should I get the 80mm or the 85mm. Any thoughts and opioons on this would be great.
DIVER8374 is offline
Old 04-05-2005, 02:50 PM
kubball2005
kubball2005's Avatar
Default RE: MAF to get or not to get??
With an aftermarket plenum I think you'd definately benefit from it.
kubball2005 is offline
Old 04-05-2005, 03:12 PM
code3GT
Mustang Nazi
code3GT's Avatar
"I" wouldn't spend the $$.
code3GT is offline
Old 04-05-2005, 03:27 PM
DIVER8374
DIVER8374's Avatar
ORIGINAL: code3GT
^^^ But will I gain anything with getting one?? I can get it for a $100 so I am just wondering if I will see nay gains form it.
Old 04-05-2005, 03:32 PM
LIVIN_LEGEND
LIVIN_LEGEND's Avatar
i have seen 8-10hp on a site that did test on a 03 GT
timing, pullys, and MAF had the best increase
LIVIN_LEGEND is offline
kubball2005
ORIGINAL: DIVER8374
ORIGINAL: code3GT
If it was 100 bucks I'd do it, but what code3GT is saying is that you could spend the money elsewhere. Him and I had this same debate awhile back in another post...
Old 04-05-2005, 04:07 PM
DIVER8374
DIVER8374's Avatar
So I will see some gains from it then. If i was to put the money elsewhere where should I put it. I have my shift kit comeing!!! And am getting gears soon also, I am running out of bolt-ons what else should I do??
Old 04-05-2005, 04:12 PM
Birdieman4
Birdieman4's Avatar
If you are eventually going to add a power-adder, like a blower, then go ahead and upgrade your MAS now to an 85. If you know for sure that you won't be adding a power adder, I would hold off.
Birdieman4 is offline
Old 04-05-2005, 04:13 PM
LuvBottles97GT
LuvBottles97GT's Avatar
I have a 85 MM C&L set up on my car, I like it, although I havent seen any #'s on it. Other parts to go with: LT Headers, fuel pump, injectors, a tire, gears, suspension....the options are endless. It all depends on how fast you wanna go and how much money you want to spend.
LuvBottles97GT is offline
Old 04-05-2005, 04:22 PM
code3GT
Mustang Nazi
code3GT's Avatar
Okay, here's some food for thought. Here are the specs of my new motor that is being built:
5cc Diamond pistons (10.5:1 compression)
Manley forged H beam rods
Forged VT crank
ARP main/head studs
Trimetal bearings
High volume oil pump/pickup tube with Billet oil pump gears
Fully balanced and blueprinted
Cams-.581/.581, 234/234, 114 lsa
Heads-Stage 2 porting/polishing (220/195@.500")
Fox Lake P51 intake manifold
BBK 75mm throttle body
Ford Racing 30# injectors
Moroso 7 quart oil pan
JLT True Cold Ait Kit
Mac long tube headers
VRS O/R X-pipe.
All of that and "STOCK" MAF.
code3GT is offline
Quick Reply: MAF to get or not to get??
