03 GT...with supercharger?...help plz
RE: 03 GT...with supercharger?...help plz
Well a S/C cant be bolted on in your driveway and you drive off and all is great. If that were the case, we would all have blowers. LOL
In order to properly run a FI application you will need to upgrade your fuel system... injectors and fuel pump so you can provide the engine with the right amount of fuel its gonna need to keep from going lean. You will also need different spark plugs.
Then you are going to need a dyno tune after its installed to get the fuel/air ratio just right to keep you from blowing your shizzle.
After the tune is complete then you are free to run. Its actually a but of work to get it all within safe parameters of operation.
Then you have to figure you will be running a little over 400hp with a good tune and will be roasting your street tires away like there is no tomorrow so you will definetly need to upgrade those.
ORIGINAL: jdaniel
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
