Diff. Bearing?
Diff. Bearing?
Im going to replace my differential bearings (are they also called carrier bearings??). Will I need to set up the gear lash again? From looking at it it looks like i could pull the whole posi unit out without having to touch the shims, but i could be completely wrong. Any ideas??
RE: Diff. Bearing?
someone with expierence.... Youre too confusing. You know what you wanna replace. The bearings on the side of the carrier. Correct.... this is what im getting from youre story. You will remove the carrier and have the old ones pressed off, then pressed back ON. You remove the shims before doing this and you use the same ones. Make sure you mark them to which way them came out and keep them on their own sides. Back lash will be the same when they came out.
RE: Diff. Bearing?
ORIGINAL: Jglisson
On the parts fiche I am showing two. One right behind the pinion gear and a another one behind the front pinion seal. It is only accessible from the front
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
ccdguy
09-19-2015 05:20 PM
