Nitrous on High Mileage Motor??
#21
RE: Nitrous on High Mileage Motor??
BUT! Looking at your mods, I notice that you don't list gears. Personally, I'd add gears WAY before adding n2o. You'll notice a BIG difference in how your car feels with a set of 4.10's or even 3.73's.
#22
ORIGINAL: MU71L4710N
PI swap and gears. surprised no one mentioned a PI swap for you yet.
#23
ORIGINAL: 03GTVert
I know how you feel, but unfortunately there really isn't anything significant you can do to actually add HP for that kind of cash OTHER than n2o.
The best part about gears is that you feel the difference any time you get on it and there's no bottles to re-fill, no window switches to worry about, no blown intakes and no additional strain on your engine.
#24
ORIGINAL: josh.davis
I wouldn't recomend you buy gears b/c with all my mods and 3.73 gear, i am lucky to pull a 13.7 N/A.if you put a75 shot on your car, you are going to smoke some ls1 and you should be in the high 12 sec quarter mile.
#25
ORIGINAL: avlon06
gears would be a good idea, noticeable difference... just cuz you run a 13.7 doesn't mean he will...
#26
ORIGINAL: BlackMUstang96GT
Where would be the best place to buy gears and what gears would you recommend? Also,What would the cost be to have someone install them? Thanks for the help!!
ORIGINAL: avlon06
#27
ORIGINAL: avlon06
got mine from american muscle and used the discount code.. and im not sure how much the install is cuz i had my clutch replaced at the same time as the gears so maybe $300 or so?
#28
p.s. nitrous is not that risky, just put in a window switch and don't spray over 100 shot on factory timing.
#29
window and wot switch at the least and i wouldnt run 100 on a stock tune. you *can*, but why risk it with nitrous. you could get a HH tuner and just knock 2 degrees of timing off or get your car dyno tuned for nitrous.
dont matter where you buy gears, motive or FRPP are good brands cant go wrong with them. get the full bearing instlal kit too especially since your car is a higher mileage car. installation will run 300 give or take depending on your area.
PI swap is just heads, cams, and intake manifold from a 99+ gt. you can get the parts for like 500$ or less from here or another forum. will give you a much better power band especially in the higher rpms and add a good chunk of HP too. dont know installation price though, most people just do it themselves.
#30
