Bullit intake manifold
RE: Bullit intake manifold
ORIGINAL: 98UAGT
No it will not, it only fits PI heads, but if you have the PI head swap, I hear amazing things about this combo, like 85 rwhp gain with both!
i thought the bullit intake just made good hp if your FI. not if your na. BUT, it may perform better since it is on a non pi motor w/ pi heads. increased compression, add some vt 2's.....mmmmm
i think your still looking at around 35-40 horse though
You'll need to do the P.I. headswap. Overall it's a better intake since it's made with aluminum and optimized for torque (it also accepts a cobra type Throttle body). The hp/torque isn't that much higher but it is higher and over the entire RPM range. Your best bet is to get ported P.I. heads w/bullitt intake and more aggressive cams. That's where the big gains can be found.
PI heads, the Bullitt intake if you go with that and the TB to match. You will need some PI cams, or aftermarket cams for serious power. I have heard stories of 45-50 rwhp gain alone from the PI head/intake swap, because on the non-PI motors it raises compression to 10.5:1. But with the Bullitt and some good cams it would be close to 80. The PI swap is one of the best mods for our cars, besides blower or nitrous.
ORIGINAL: 98UAGT
You will also need a new dipstick tube and coolant tube along with new head gaskets and bolts.
