Turbo Mach 1
2010 Blue Ball Award Recipient
RE: Turbo Mach 1
forged internals
I don't think anything else is up to the numbers or punishment the Cobras are.
RE: Turbo Mach 1
ORIGINAL: 72MachOne99GT
I could be incorrect, but I believe that the Machs only have a forged crank in the 5sps.
forged internals
RE: Turbo Mach 1
ORIGINAL: jrherald420
+ its an auto mach 1... non forged internals + turbo = one big repair bill in the future !!!
RE: Turbo Mach 1
Well if its an azure blue mach 1. With a turbo I say jump on it. My got rid of his last year. Built 4v motor, 76mm turbo.I believe, maybe bigger
Built auto with a 3400 stall. the car made some power. He used to walk on 03,04 cobra b4 whipple and kb started making blowers for them.
If any1 wants to see a vid of the car I speak off. Go on youtube and type in turbo mach. It will be the 1st video. Very good vid. For back in 2004
RE: Turbo Mach 1
ORIGINAL: Stone629
Exactly, if that motor isn't built, its a time bomb. Mach 5spds came with a forged crank, the automatics did not. Either way, the rest of the motor is the same as the GTs, and the safe limit is still 450rwhp (for a limited time). If the trans is stock, it'll be the first thing to letgo. I would still check it out, it could have a built DSS block and built tranny for you know.
go on m1r there are alot of machs with over 450 rwhp and still on stock bottom end. my tuners friend has a mach with a kb pushing 550 to the wheels on a stock botom end. as long as youdont detonate your fine.
RE: Turbo Mach 1
but how often does he use all 550 hp???i bet its not very often. you could have600-800 hp on a stock bottom end and never take it over 70mph or get onitand it would last for years, but a couple ofgood passesat a strip and its over!!!
RE: Turbo Mach 1
ORIGINAL: 5speedstang
the rest of the motor isnt the same. 4v heads? way differnt intake? how can you say rest of the motor. the machs have 10:1 compression. gts i think are 8:1.
ORIGINAL: Stone629
