which spark plugs should I buy
Time for new plugs, i read some things on here but then I went to sparkplugs.com and saw a lot of different ones which is the best or if you dont feel like looking at the link which should I buy. I do weekend drag racing with the car and not much more. I dont drive the car everyday.
here is a link to the plugs http://sparkplugs.com/results_app.as...p;AAIA=1372654
Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Power Tip, Copper Core, Platinum Tipped Center Electrode and Platinum Tipped Ground Electrode ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
Autolite
Double Platinum
APP764
APP764
.054"
$5.42
Iridium Enhanced Plug, 14mm Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Full Thread, Copper Core, 0.6mm Finewire Center Electrode Design, Platinum Sidewire Technology ', 325);" onmouseout=hidePreview(); bgColor=#b3d2ff>
Autolite
XP Iridium
XP104
XP104
.054"
$6.24
Iridium Plug, 14mm Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, .052" (1.3208mm) Gap, Special Firing End Construction, Extremely Long Life Plug, Iridium Center Electrode with Platinum Tipped V-Trimmed Ground Electrode ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
Champion
Iridium Plug
9204
9204
.054"
$8.27
Gold Palladium Performance Plug, 14mm Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Copper Core, Projected Tip ', 325);" onmouseout=hidePreview(); bgColor=#b3d2ff>
Champion
Premium Gold plug
2401
2401
.054"
$2.51
Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Platinum Tipped Ground Electrode and Platinum Tipped Center Electrode, Projected Core Nose ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
Champion
Double platinum
7963
7963
.054"
(Original Equipment Manufacturer and/or Original Equipment Equivalent)
$5.78
Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Removable Terminal, 0.4mm Iridium Center Electrode, Tapered Cut U-groove Ground Electrode, .044" (1.1mm) Gap ', 325);" onmouseout=hidePreview(); bgColor=#b3d2ff>
Denso
Iridium plug
5325
IT16
.035"
$11.99
Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Solid Terminal, Platinum-tipped Ground Electrode and Platinum-tipped Center Electrode, Extra Projected Tip, .050" (1.3mm) Gap ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
Denso
Double platinum
5070
PT16EPR-L13
.035"
$6.82
Platinum Plug, 14mm Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Solid Terminal, Projected Tip, Fine Point Platinum Center Electrode and Platinum Tip Laser Welded on Ground Electrode, .044" (1.1mm) Gap ', 325);" onmouseout=hidePreview(); bgColor=#b3d2ff>
NGK
Double Platinum
6579
PTR5F-11
.054"
SOHC
$11.71
Iridium IX Plug, 14mm Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Removable Terminal, Projected Tip, Fine Wire (0.6mm) Iridium Center Electrode, Tapered Cut Ground Electrode, .059" (1.4986mm) Gap ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
NGK
IX iridium
7164
TR55IX
.054"
SOHC
$7.32
Iridium Plug, 14mm Thread, 18mm (.708") Reach, 5/8" (16mm) Hex Size, Tapered Seat, Resistor, Special Firing End Construction, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Ground Electrode, .050" (1.3mm) Gap ', 325);" onmouseout=hidePreview(); bgColor=#b3d2ff>
NGK
Laser Iridium Long Life
6044
ITR5F-13
.054"
SOHC
Autolite
Double Platinum
APP764
APP764
.054"
$5.42
Autolite
XP Iridium
XP104
XP104
.054"
$6.24
Champion
Iridium Plug
9204
9204
.054"
$8.27
Champion
Premium Gold plug
2401
2401
.054"
$2.51
Champion
Double platinum
7963
7963
.054"
$5.78
Denso
Iridium plug
5325
IT16
.035"
$11.99
Denso
Double platinum
5070
PT16EPR-L13
.035"
$6.82
NGK
Double Platinum
6579
PTR5F-11
.054"
SOHC
$11.71
NGK
IX iridium
7164
TR55IX
.054"
SOHC
$7.32
NGK
6044
ITR5F-13
.054"
SOHC
RE: which spark plugs should I buy
what year is your car? I was about to run NGKs on my windsor 00 too but it had more threads.. a lot more threads thanthe head and a lot more threads than the old plug had. I took it the heck back and got some autolites, i wasn't risking a blow out.
I think the newer stangs 01.5+ have more threads on their heads though.
Motorcraft ASF32C copper plugs if you are NA.
http://www.spark-plugs.org/motorcraf...0W9FAHWID.html
NGK TR6 if you are FI.
Forget the exotic plugs.
ORIGINAL: Jbauer
Ford went to the plug with more threads to help prevent blowout.
Motorcraft ASF32C
I bellieve the 'F' means full length thread.
More threads may be better on a head that HAS more threads-i just did not feel comfy putting those NGKs in.
The NGK had 300% more thread than the autolites! i just don't feel they belong on a 99-00
Golfsito
10-06-2015 11:02 AM
Omgitsa88Stang
10-05-2015 07:33 AM
