PI Swap question!?!
PI Swap question!?!
should i go with Patriot stage II heads and stock intake or should i go with stock heads and aftermarket intake? my funds are limited at $2000, so keep that in mind. and next question will the T/B and plenum from a 98 fit on the lower intake on the 99 - 04??? thank you!
RE: PI Swap question!?!
Well first off im pretty sure question #2 is a no. And def. the patriot heads, the stock intake flows pretty well. You could shop around and prolly afford both, or port and polish one of the two. good luck, maybe sumone will add a little on to this for you.
ORIGINAL: Warrior62
ORIGINAL: silverstang1996
well first off you shouldn't be giving advice of things that you don't know for certain because in this case you're very wrong. 96-04 plenums are all universal. so a 98 plenum will fit 99-04 no prob. heads are what you want done up. I'd suggest doing all basic bolt ons before head work and such, because to see good gains from those core parts, you need good bolt on parts for maximum benefit.
ORIGINAL: Warrior62
oh and npi intakes are a joke, they DON'T flow well.
yup u can go full bolt ons with that money I dont think I waisted that much for all my stuff and I have mostly everything..
01 pI motor $500 low miles, good for spray
ported heads.. all portedshop work a hook up was $1,100
ported upper & lower intake manifold(bullit).. gift for messing up first motor ( not the second shop)
ported 03 cobra throttle body $30
03 cobra bbk cai $50
hooker ceramic coated long tube headers
borla x pipe, slp lm1 $300 for lts and x pipe
stage 2 patriot cams $200
king cobra clutch $200
(dyno tune coming soon triangle speed)
look around on craigslist.org and look for ur city u can find cheap stuff there and still good man I got 90% of my mods from there
umm it looks like he has most, if not he has a lot. i know that you can get PI heads and intakes off ford's website for like 600 all around and then maybe just get the intake ported, BUT it would be better to save up some more and just get both ported before you put them on there so you dont have to do it later and then they have to retake the entire engine out and put it back in. thats the same labor cost twice, which would be stupid
MODULARRACING
HEADS AND CAMS
PI HEAD SWAPS
SHORT BLOCKS
LONG BLOCKS
ROTATING KITS
CONTACT US
HOME
PI CONVERSION KITS
98 AND OLDER 4.6
Pre 99 heads had small ports and valves, and large round 52cc chambers. Camshafts in these heads were only .460’’ lift with short spring heights, you CANNOT install high lift cams in these early heads. Considering all these facts we feel modifying early SOHC heads to be a waste of time and money. . .
BOLT ON 65—110 RWHP ![/align]
Our kits contain new 2001 GT “Romeo†heads, with .510’x.530’’ cams & improved intake that will wake up your engine like you wont believe !
STAGE I KIT = $ 1595.00
STAGE II KIT = $ 2695.00
New 2001 GT box stock romeo heads w/.510’’x.530’’ cams complete/assembled. New 2001 GT intake manifold, water transfer tube, head bolts—head gaskets. Intake/exhaust gaskets, cam sprocket bolts
65 RWHP !
Same as stage 1 plus . . .Competition porting, competition valve job, Ferrea SS forged valves, 7000 rpm spring package, flow bench tested—professionally assembled . . .
110 RWHP !
Want to sweeten the deal up and add 15 RWHP to either kit ?[/align]
ADD $400.00 for your choice of HOT/PRO STREET CAMS !
HOT STREET
540’’X.540’’X 215d@.050’’x 114 lsa
PRO STREET
.540’’X.540’’X 225d@.050’’x 112 lsa
All cams are “re-engineered†and come with our custom lash correction caps
jaiidutch
09-14-2015 10:29 AM
