Question about my mods and running lean
RE: Question about my mods and running lean
ORIGINAL: oxfordgt
Your about 60hp away from needing to upgrade injectors. But if you get to the dyno and the tuner tells you need to upgrade tell him to eat **** and up the fuel pressure. 19# injectors at 85psi will function as 30lbs injectors. And don't worry the incectors handle 100psi. But you will not need to upgrade you fuel system with your mods.
At 300 your right on the edge, you will have to see what happens. Even if they work, make sure your tuner checks the duty cycle... if they are nearing 100 percent duty cycle they will wear prematurly and cause problems.
Calizic
08-28-2015 01:46 PM
