Which Cams /w Pi Swap
Which cams can be used on pi swapped cars. I know theres a problem with ptv with the compression diff so i need to know which cams i'm limited to or what people are using. I know vt stage 1's will work but stage 2's? Which comp cams will work and are reccomended for full bolt on car?
Comp XE265H, XE274H, XE270AH areones i have been looking into, are the XE262AH even worthit?
RE: Which Cams /w Pi Swap
Ive got comps stage 2 npi cams and they do good, but I could have prolly gotten away with the stage 3 npis. You may be able to get away with a stage 2 pi cam if you degree them, but I'm not sure.
ORIGINAL: whitestang97
im goin to put xe278ah's when i do my pi swap...but the majority of people on here will probably say thats a bad idea...and i'll have ptv issues...but i'm still gonna try it...
When you say you have comp cams stage 2's which ones are you talking about, I'm really hoping i can find a set of comp XE265's or XE270's or vt stage 1's. I think they will be best with my set up. Are npi cams .50 lift and pi's like .545/.550 ?
ORIGINAL: 8111870a
i have the xe262ah in my pi swapped 96 and i love them
no low end loss and they pull all the way to redline.
perfect for a daily driver, and install was easy.
ORIGINAL: StangEatsRice
