What wire is what for each coil?
I am installing a window switch and need to know wich wire is the ground wire to a coil on a 2002 gt.
Each coil has a red wire I believe then one other striped/colored wire.
RE: What wire is what for each coil?
the ground should be in the harness adapter located on the passenger side next to the firewall pin #34 is the output for the tach it should be the same as a tach adapter install ground it to the ground located left of the harness
jwog666
12-27-2021 08:09 PM
