Big spark plug problem
RE: Big spark plug problem
How would torque have anything to do with them cracking? Your not torqing down the porcelain portion of the plugs. The clogged catalytic converter sounds possible. The cat doesn't need to be completely clogged for there to be excess backpressure. It may run just fine under normal driving conditions and just not allow enough flow at high rpms. There has to be something causing extreme cylinder pressures to get a spark plug to do that. Unless you happen to be the unlucky person who got shafted with a bunk set of plugs. But 3 in a row sounds like something is killing them for you. Were they all on the same side?
YEah over torque won't cause the ceramic part to break. It looks like the ceramic part is almost popped out.
Looks like Champion FTL. I've only trusted NGK, Denso, Motorcraft, or Bosch.
First off stay away from Chumpion plugs, as stated they are great for lawnmowers and such--Motorcraft or NGK-- and nothing else was said about the bottom part you said fell into the motor, or did it just burn off the electrode. Looks to me as if you got a bad batch of plugs is all, it happens or do you still have that silly rubber insert inside your plug socket, with that still in there it makes it easier to crack the top of the plug just like yours when installing/tightening them. Just the slightest tilt of the socket and they will crack.
ORIGINAL: effingroovin647
such an overwhelming amount of responses.... i went to ford today and brought the plug with me. They told me i either have a clogged pcv valve or a clogged catalytic converter because what happened to the spark plug means theres alot of backpressure building up.
musnicki
09-23-2015 07:11 AM
