Need more Power!!!
RE: Need more Power!!!
Gears, plain and simple. Do nothing else but put in 3.73 gears and you won't believe it is the same car....guaranteed! Worth every penny and then some due to the "wow" and "fun" factor. Don't be timid. Just do it. Without the gears your car is about a 145 mph vehicle. You may come down to 135 or so with gears but that is not where the fun is at not to mention one wrong fart at that speed and you are toast.
A couple of other mods worth mentioning are the Accufab plenum and underdrive pulleys. I have both on my '98 GT auto (wife can't drive a stick) along with a Ford Racing 70mm throttle body and the car is as smooth as glass. Not one problem of any kind......except when I ran over some road rash coming out from underneath a truck in highway rush hour traffic....it very surgically removed my two back oxygen sensors. Accufab flows the most CFM and showed the largest total increase in HP and torque over the other competition. The 75mm throttle body really didn't show any improvements over the 70mm with the Accufab. I think you would have to be force inducted to really gain there.
If you want to go nuts with power and cost (they kind of go hand in hand), just get a blower of some kind and realize a cool 50 to 100+ HP gain. But, you really should freshen your engine at the same time unless you have very low miles otherwise things could come apart on you.....not a nice feeling when it does.
Gears....they are your real solution. Have fun with your ride and don't lose heart. That Acura probably cost way over $15,000 more than your Mustang when new. For just $3,000 or less you would absolutely toast it! One last option......buy a Cobra!
Lol your intake is probly giving you 5hp at the wheels IF YOUR LUCKY, 25hp you wont feel a diff at all, trust me. Get gears.
Im not talking Cold air intake.. we are talking about an intake manifold
Ya, I guess gears do sound like the best bet.
next thing im doing to my car is gears... i wanna to break into the 9's in my stang.... i can do that with just practice but i want it now!!! so what is the difference between the accufab plenum and the C&L plenum? i heard they are about the same but im not sure?
ORIGINAL: Ck9887
No I dont have a PI swap... Just the intake.
The difference between PI and non PI is 35hp and my intake is 15hp so PI Heads and Cams will give me another 20..
ORIGINAL: Deannostang
[8D]
ORIGINAL: Dan02GT
Good post other than the mis-information about top speed. Top speed will actually increase with a shorter gear change thanks to our poorly geared transmissions and weak HP stock
[8D]
[8D]
[:@] because from what i read that guy was saying u will lost top speed with them. He never mentioned shorter gears...
ORIGINAL: GT1999
anything shorter than stock gears IE 373,390,410 will take away from your top speed... if u get longer gears than stock, which i dont know why anyone would, then your top speedwill increase
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
