Broken Mounts???
Old 04-16-2008, 12:06 AM
tcuallstar
tcuallstar's Avatar
Default Broken Mounts???
Im starting to think that either my tranny or motor mounts are broken, i get a clunk noise any time i am in gear and let off the gas and then get on it again or from a start depressing the clutch and changing gears. my question is, how hard is it to tell if they are actually broken? are these things that can easily be replaced without too much work?
tcuallstar is offline
Old 04-16-2008, 09:57 AM
1sloblckgt
1sloblckgt's Avatar
Default RE: Broken Mounts???
Could be your U joints....
These trannys are very "clunky" anyway.
1sloblckgt is offline
Old 04-16-2008, 09:59 AM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
Put your car in gear and try to turn your driveshaft. Is there alot of play in it?
35thAnni99GT is offline
Old 04-16-2008, 10:06 AM
tcuallstar
tcuallstar's Avatar
When i checked that the last time i had it up in the air, it didnt look like anything out of the normal, i only have like 35K miles on my car, so im having a really hard time believing its the u-joints. all though my car is lowered, so that probably changed the pinion angle and could cause them to wear out faster. am i right?
Old 04-16-2008, 10:13 AM
GodAmGT00
GodAmGT00's Avatar
Well, changing pinion angle could affect the tranny mount as well.. A good way to tell, IIRC, is when looking at the tranny mount, there's normally a little gap in the middle of the mount, to allow for flex.. If the rubber has deteriorated, the center will be compressed, or flush with the bottom of the mount.. Get the front of the car up in the air a little, and put a jack under the back of the tranny housing, and jack it up a little.. Watch the mount, and if you see it separate into 2 pieces, you'll know right away what I mean, that's your culprit..
You can also visibly see the engine mounts, although slightly obscured.. There should be a nice piece of rubber that's not squished or cracked.. If you so a similar jacking of the front of the engine, with a piece of wood between the jack and the oil pan, you should see most of the front of the car lift, and not one particular side of the engine lifting..
How hard do you beat on your car?? U-joints can last 100k miles or 10k miles for a variety of reasons... If you can get the drive shaft off, move the pinions and see if there's any lateral movement or clicking.... Don't forget to index the pinion flange for correct re-installation alignment..
JT
GodAmGT00 is offline
Old 04-16-2008, 11:11 AM
tcuallstar
tcuallstar's Avatar
Thanks ill check it out. i dont romp on my car too much, and i dont have any crazy mods or anything. if i replace them should i switch to poly or just go with the stock OEM ones
Old 04-16-2008, 11:24 AM
GodAmGT00
GodAmGT00's Avatar
If you're talking engine mounts, I'd say go urethane, since they tend to last longer, can take more abuse, and help transmit more power to the ground (although it's negligible)... As for the tranny mount, why not?? At least where I'm at, you can only get the tranny mount from Ford, and it cost somewhere around $130 + some tax.. I think the urethane one is a little bit more, and can be found on Ebay, as I'm not sure who makes them since I haven't been parts searching for over a year now...
JT
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
09-25-2015 06:58 PM
Quick Reply: Broken Mounts???
