Degreeing Cams How To?
I just got my cams and am wanting to get them put in, the only question I really have is about degreeing the cams. I have never done anything with them before but I believe it means basically having both sides of the motor set exactly the same. How do I check this? I know that not all cams are perfect and have heard that sometimes there is even variations in the degree of a set of camshafts. I know I can install them straight up but this is not best ( for ptv or hp). Really I need a write up on this or some serious help. Any would be apprecaited. I did search this but didnt come up with much.
RE: Degreeing Cams How To?
Before attempting to degree a camshaft, you should fully educate yourself and completely understand the 4 cycles of a 4 cycle engine. (Intake, compression, firing, exhaust.)
Until you do this, the process of degreeing a camshaft will seem fuzzy and confusing.
Good luck on finding info on this one, I tried and nobody seems to have it. There is a senior forum member I pm'd who said he's going to research it and post a sticky on it when he gets time. So I guess when I'm ready to do this I'm just going to go to my engine machinist who specilizes in ford motors. Good Luck.
ORIGINAL: 98SN95
welll im not exactly sure about this cause ive only done it about 2 times but, you can degree the cams by checking the static comp. ratio.
