How wide are stock Wheels
RE: How wide are stock Wheels
I just got some 18x9 front/ 18x10.5 in the rear... They Are black Saleens and I havent got them yet and My car is about to go get painted and the 3" cowl hood mounted then tehy will be put on... I'll Try to get a pic up asap.
ORIGINAL: jmac72187
Some 99-00 GT's came with 16" wheels. 17" was an option in those years. They looked like this:
ORIGINAL: 35thAnni99GT
Wasn't there a GT that came with a 16? or am I thinking of NPI GT's?
reguardless point proven not all gt's had 17x9's. and 17x9 look fine in the front, if anything you want wider on the back.
and no it doesnt matter how wide your tire is it only matters how tall it is (for the speedo)
ORIGINAL: bjh061487
no matter what the number its not wide enough... is it true that if you get a wider tire or wider rim that you need to recalabrate the speedo?
Location: Where gunshots are more common than birds chirping
ORIGINAL: SXGT
wider no, taller... maybe.
ORIGINAL: bjh061487
directly no
indirectly it may. you have to get a wider tire than what you had before and if you don't match the profile size correctly and end up with a tire with a bigger sidewall then yes.
actually yes and no
directly no
ORIGINAL: SXGT
ORIGINAL: bjh061487
directly no
If you go from a 17x8 and run 245/45/17 and then switch to a 17x10 or something and run a 295/45/17 the sidewall profile will be alot larger and in turn make the tire "taller"
thats the only point i was making.
ORIGINAL: MU71L4710N
those look like v6 rims???
ORIGINAL: jmac72187
M3hunter
09-05-2015 03:42 PM
