Where can you buy domed pistons?
Old 04-22-2008, 09:53 AM
snorulz
snorulz's Avatar
Default Where can you buy domed pistons?
Hello,
I work for a professor part time right now and i am setting up a single cylinder test engine. It happens to be the same stroke and bore as a ford 4.6L. He would like to boost the compression ratio for some of the test and it looks like the best way would be to use a domed piston. I have not been able to find any and was wondering if any of you have a link to a supplier that sells them.
Thanks
snorulz is offline
Old 04-22-2008, 10:38 AM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
Default RE: Where can you buy domed pistons?
errrr... keith black, eagle, probe, just to name a few.
Why don't you take the head and put it on a belt sander and mill it down a few tenths. Should raise the compression some.
35thAnni99GT is offline
Old 04-22-2008, 12:07 PM
snorulz
snorulz's Avatar
it is not a ford head and it looks like there will be an issue with the valves if we take much off
snorulz is offline
Old 05-21-2008, 09:21 AM
snorulz
snorulz's Avatar
does anyone have any links to where i can find some? I still am having trouble locating any.
snorulz is offline
Old 05-21-2008, 10:50 AM
Subotai_95
Subotai_95's Avatar
You could try Lethal Performance, I know they sell several types of heads.. Or Steeda, or D'Agostino Racing, or JEGS.. There's probably more, but I don't know if you've tried any of these yet..
Subotai_95 is offline
Old 05-21-2008, 02:19 PM
10inch Terror
10inch Terror's Avatar
You won't likely find ANY domed mod-motor pistons as shelf stock pieces...they will likely have to be custom made with a dome.
10inch Terror is offline
Old 05-21-2008, 10:08 PM
snorulz
snorulz's Avatar
thanks, that is what it was looking like
snorulz is offline
GimpyHSHS
19
12-19-2023 01:12 PM
ChampInSD
10-02-2015 04:55 AM
winner99
10-01-2015 10:52 AM
09-25-2015 06:30 PM
Quick Reply: Where can you buy domed pistons?
