Headers Demystified! HP Gains or Not..
#41
RE: Headers Demystified! HP Gains or Not..
wow with just CAI TB/plenum and weld in flows and a can tune with a messed MAF i had 241whp and 273ft/lbs, since then I installed al d/s o/r x-pipes pullies and a stewart waterpump, I wonder how much I'm putting down now . Anyways back to your car you should get a sound clip up so we can hear it clear its throat!
#43
ORIGINAL: bolt.com
also.........I ran into an '03 Cobra guy yesterday who was flaming aftermarket throttle bodies, inlcuding the more expensive one's. Said they frequently experience failure for whatever reason. Told me to stick to stock throttle body and plenum for more reliability...........
Almost every piece on the market is a safe bet. Accufab, MAC, BBK, FRPP, PP, etc.....
Newbie to domestics here...........****, only 9hp from headers!!! Yikes!!
Just picked up an '03 GT.....stock except for K&N cone. I traded in my VQ Altima with full bolt on-'s.............and seeing this thread, now I know why I was able to pull pretty hard on some Mustang GT's from a roll over the past couple of years.............
Looks like bang for the buck, gears and H-Pipe are the best for starters.............and I see cams are dirt cheap for these cars!! Geez.........cams for my Altima were way out of reach at $1,500 per pair.
PS......Im a bit tight for mod $ now but would you guys say that H-Pipe and a couple of Flowmaster mufflers would be a cheaper way to go to free up some power? Seems the stock mufflers and the aft cats are real restrictive............
#45
I know a local Ford mechanic who installed LTs on his GT. When I suggested he install them on mine, he said no way. Unless you have mechanical ability, it is one of those mods you do not want to do yourself. I've heard 10-12 hours if you are doing it in a driveway and not dropping the K-member. I had Automotive Specialist install mine. They have special tools in place to hold the motor when they drop the K-member.
But, now that I have LTs, I'm not sure they were worth the money.
#46
ORIGINAL: Jasperstang308
are long tubes really that hard to install on these motors?
#47
I wouldn't suggest doing the install in your garage either. I would def recommend using a lift. I did in my garage and it was just terrifying. Looking at your at car on the third day is the worst. But once it's installed it is all worth it..
[align=left] [/align]
junior04
09-28-2015 10:53 AM
