Removing outside trim above windows.
I am trying to get the plastic piece the goes over the windows off. I know you have to take the quarter window pieces off. Is there anything inside the car that needs to be unscrewed or do they just pop off?
RE: Removing outside trim above windows.
You have to remove the A pillar, and then flip up the little rubber pieces in the inside of the car. There are screws that hold it to the car. Take those out and then it will pop off.
Pull off the window gasket, it just pulls out of a track. The then look in the track and you will see a lot of screws, remove them and the track. Next where it attaches to the roof there are screws that have to be removed and there are clips that hold it to the A-pillar and on bolt that is at the base of the A-pillar and it will come off. Be careful when pulling it away from the a-piller as the part is fiberglass and will crack
You have to go inside the car and remove some of the screws in there. Just be careful when pulling the plastic peices off the car thou. Cua when i did it i pulled a lil to hard cuz they are so snug and it cracked some of my paint and i had to get it fixed.
jwog666
12-27-2021 08:09 PM
