How to get Oil Dipstick out of block?
In the middle of a PI swap and cannot get the drivers side head off. I think its because of the oil dipstick. How do i get it out. I think i read before that someone broke it and were able to get the head off. If thats the way to do it where do i break it. If not what to do. I tried yanking on it hard as hell couldn't get it. The new one in the ford racing kit looks to just be an o-ring seal with no bolts. Is that how the stock one is?
RE: How to get Oil Dipstick out of block?
Theres one small bolt bout half way up which keeps it in place, other than that its just an o-ring. Im not sure if you can access the bolt from the top though
Yeah its one bolt that holds the tube to the head, and just an o ring in the block like ponysnake99 said. Mine was a bitch to get out though. The o ring really held it in there.
There is a bolt on the valve cover that holds it down. I had to bend and break mine to pull it off without removing exhaust manifold. It is really a two or three person job and its also the most stressful part of the pi swap when you put the new dipstick in.
i was able to pull my dipstick out no problem after removin that bolt, i actually had to just replace the tube cuz there was a hole in it down near the bottom, no idea how the hell it got there but it was leakin oil haha, but goodluck with the tube.
Matt's 95 Stang
10-05-2015 07:16 AM
