Redline MT-90 in a T-45=ok???
Old 04-26-2008, 02:36 PM
kylebgt
kylebgt's Avatar
Default Redline MT-90 in a T-45=ok???
I will be changing the fluid tomorrow and picked up 3 qts of Mobil 1 synthetic atf. I know the manual calls for like 3.2, so I figured I would add about 1/4 of a qt of Redline MT-90 that I have left over. Is it ok to add this to atf? Also is there a good write up for changing the fluid? I know its fairly simple but am not sure where I am supposed to fill it through the shifter.
kylebgt is offline
Old 04-26-2008, 02:42 PM
Mark99GT
Mark99GT's Avatar
Default RE: Redline MT-90 in a T-45=ok???
I personally wouldnt mix fluids. To fill it, you just remove the shifter and pour it in. You're supposed to remove the top fill plug and fill the transmission until fuid just starts to leak out of the fill hole. You could also use a pump to pump fluid in from the fill hole (its in an awkward position though). Make sure the car is level if you do it this way.
Mark99GT is offline
Old 04-27-2008, 02:26 PM
kylebgt
kylebgt's Avatar
anyone else? I really cant justify dropping another $8 for a 1/4 of a quart. I think that mt-90 is gl-4 is this alright? Thanks!
kylebgt is offline
JoshyGT
09-19-2017 08:52 PM
Greyshot
08-15-2015 03:32 AM
imported_admin
12
12-16-2004 07:43 AM
brent etter
08-31-2004 04:24 PM
Roundabout
11-15-2003 08:59 PM
Quick Reply: Redline MT-90 in a T-45=ok???
