430s cover
RE: 430s cover
A Ford Tech actualy told you that?[8D][:@] No you do not need a different cover for 4.30's
If he was talking about a Girdle Cover for support that would make sense but still not needed
http://www.lmperformance.com/3570/50.html
FYI if this is the same guy that you are gonna have put them in I would look else where. Just my .02
RE: 430s cover
maybe a new carrier not cover tho. cover has nuthign to do with it the gears are still 8.8" diameter its just the teeth are different. i'm sure he ment carrier. but i don't know if u need a new one or not
RE: 430s cover
Yes this is from the guy im trusting to put them in.[sm=smiley36.gif] He said he wasnt sure if i would need one. He has put in new ones at ford but just factory parts. He wasnt to sure about performance gears.
RE: 430s cover
how bad was that on the install?
im not bad with car but i aint great?
he was to tell me how let me do it and him help if i run into trouble.
never change gears before. is it real hard?
and i was also wondering if what the biggest camshaft i can put in mine without changing anything?
and how hard is it putting cams in?
can u leave the motor in car when doing it?
RE: 430s cover
ORIGINAL: Jordan123
I just order 430s for my 99 get and a ford tech told me i prolly gotta get a new cover for that steap of gears
is that true?
is that true?
RE: 430s cover
The install was actually pretty easy. I had a good set of instructions and took my time. Have had no problems at all. I'm a strong believer that no job is too hard to do yourself if you have the right tools, some patience and good instructions.
As for the cams, they should be last on your list. You won't see much of a gain from them for what they cost. That install is a bit more involved since you have to degree them to be absolutely safe. Doable, but more complicate.
RE: 430s cover
unless you know what your doing i would strongly discourage doingn your own gears. Even professionals mess this up.is it really worth blowing up your rear end because you wanted to save a little money. i do everythign on my vehicles but gears is one thing i will not touch. leave it to the professionals.
RE: 430s cover
If you can't read and don't know how to turn a wrench, then do what this guy ^ says. Otherwise, just be sure you have the right tools and the instructions. I had never done a gear swap before doing mine and I have had 0 whine. I hear about people taking their car to "professionals" and paying out the a$$ only to complain of whine right away. I did my gears just about a year ago and I have had no problems what-so-ever.
Doing your own work on the car is a great way to learn, as well as to be sure everything was done right. Took me three attempts to get the backlash right (shimming and what-not) and I doubt every mechanic is going to take the time to do that on a car they don't care about.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
