transmission rebuild???
RE: transmission rebuild???
Here's the direct link from the driven man's T45RS:
http://www.thedrivenman.com/KE/Ford/...ions/T-45R.htm
Before you jump off the cliff for the T56, consider the overdrive ratio unless your planning on a T56 viper spec. To get one of these installed you're probably going to get raped because they'll tell you that it's not a direct swap. But I guess for that T56 kit for $2899 is not that bad of a deal. I just don't think there is much of a benefit to go from a .68 or .64 to just get a .62.
ORIGINAL: bullittracr
whats the fifth gear ratio for the t45's
