A/F ratio codes
RE: A/F ratio codes
ORIGINAL: oxfordgt
I wouldnt worry about it. If that is a canned tune you have then you are running a bit rich and will be fine. You don't have any mods that will effect your A/F ratio.
RE: A/F ratio codes
+1,000 do NOT mess with fuel settings without a wideband sensor. Also, you will find that when tuners say "it's set at about 13.0:1" they are referring to the AFR in open loop, at or near WOT, under heavy load (as in wide open on a dynamometer)--that's the way they think.[/align][/align]At partial throttle and light to medium loads (I.e. closed loop operation) it will roam from14.3:1 to 15.2:1 so as to average 14.7:1. Maybe even a bit higher (as high as 16.0:1) at steady light loads (like 60 on level ground), as that's where the best fuel economy is. The tuners don't mess with closed loopsettings much 'cause there's not really anything to be gained there...[/align]
RE: A/F ratio codes
LOL no. 12.5 is the safest for best power 13.2:1 is lean but best torque production 11.5:1 is rich but best torque on the rich side. Of course those numbers all move richer by a full point when your FI. 12.5 is very safe for a stock engine, by the way the heads and cams are the only thing left on my car that are stock.
RE: A/F ratio codes
ORIGINAL: Romer
But wouldn't 12.5 be way too lean for a stock motor? 13 sounds extreme
RE: A/F ratio codes
ORIGINAL: oxfordgt
Don't touch the A/F without a wideband. If it is actually set at 13:1 then leave it. That is the max power your gonna get from a/f adjustments. Try maxing out the spark.
And when we talk wideband were not talking about the $25 light show from autometer. I paid $315 for mine. Innovative with band with the XB16 gauge or something like that
lincolnshibuya
12-08-2015 04:37 PM
