just bought 04 gt, hows this for starters?
RE: just bought 04 gt, hows this for starters?
shadow how do you like your 125 wet shot? think that i may order this week and get the remote bottle opener will be putting on a stock gt with a new cat back sysem just wanted some feed back on how someone likes it
Besides that this is what i wanna do for starters, let me know what you think BBK seemed to be the cheapest brand for most of the parts. heres what i came up with.
CAI, TB, upper plenum, underdrive pulleys, headers, exhaust.
instead of the underdrive pulleys i would go with a set of 3.73's (b/c its a 5 speed) and if your tight on money i would go with a midpipe and a cat back keep the stock manifolds and run some spray.
As someone who has 4.30's I can tell you that they will be too much gear for a car with any sort of F/I without a built motor and suspension and a taller tire. If you want to get a lower gear, go with 4.10's. I'm N/A and I cross the traps towards the top of 4th at 102 mph on a 26.1 inch tall tire.
well im actually a ford tech lol. So install is free and ford racing parts at slight discount. Plus tons of resources at the shop. So if gears are $550 installed, and its probably a 2hr job at $90, the gears are around $300
I just got a bbk h-pipe and what i think are stock mach 1 mufflers from another tech at the shop and i installed them after work. took like 2 hours cause i had an issue with the lower stud on the passenger side. that things tucked away nicely. so now it sounds a lot better but i got a MIL. butt dyno shows no noticeable results.
next is throttle body, plenum and spray..
still researching gears. Moser? Ford racing?
mm damn thats awesome. id definitely do gears, 3.73 and then blow your baby later
yeah definitely skip the CAI and UDPs especially if your getting a SC.
orr why dont you turbocharge it
i would get a set of 4.10s then what this guy said
ORIGINAL: Mustang3GT07
I would do the longtubes, mid-pipe & catback. Then save save save for a supercharger!!!
