wow changed fuel filter
#22
RE: wow changed fuel filter
ORIGINAL: GodAmGT00
Hmm, well, steer clear of the platinums, but there are some good choices on plugs.. It's been a while since I've done plugs on a Mustang, so I couldn't give you a good idea, other than Motorcraft or an equivalent..
Also, I meant to ask, is this after the car is already warmed up?? I think that it is.. It may not be a bad idea to get an idea of what the coolant temp is reading (if you can on the Diablosport).. Also, when it started back up, was it skipping right away, but still driveable, or did the skipping/missing start after you had load on the engine for a little bit??
yep only after a load for 2 miles then i was home.
JT
JT
no yesterday running so bad it would not move..........i pulled over cut off cut right back on and made it home fine started to stutter a little 2 miles down the road.... That particular restart took a good 7 seconds to start... other then that it starts fine..
