Tach Voltage?
Tach Voltage?
Does anyone know about what the output voltage should be for a tach lead?
My window switch is not working, and I want to check the tach signal before I replace the whole switch.
Thanks!
Thanks!
RE: Tach Voltage?
If you are referring to the CTO (Clean Tach Output) signal from the instrument cluster (or pin 48 on the PCM), it should be 3.0 to 9.0 volts when measured with a multimeter (it depends on the frequency response of the meter).[/align] [/align][/align]--------------[/align]edit -- engine idling...[/align]
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
