oxgen sensor help!
oxgen sensor help!
i hooked my car up to a scanner today and got the P0133 code for bank 1 sensor 1 slow response. i have stock manifolds.
can i just use the tuner to cancel the code and be done with it? i don't really need to replace the o2 sensor do i? i don't see how the exhaust not heating up fast enough would cause any problems, but i'm not an expert. help plz!
RE: oxgen sensor help!
How many miles on your car. You can clear the code, but it'd just going to come back if there is a true issue. If you end up replacing your o2 sensor, make sure you do it w/ ford parts. I attempted after market from autozone and the screwed everything up. Went back and put in stock o2 and everyhitng was fine. Your going to pay abput $80 a pc.
ORIGINAL: sfi
what brand are the OEM sensors? motorcraft?
go to a ford dealer and get the part. Most ford dealers do it at cost anyways. When they told me the price per o2, I *&^*&^. Let them know you can get a o2 at autozone for $45 and they probably will lower your cost. It worked for me. You car is ready for 2 new o2. Ford recom. them at 60,000 miles. Realize you have 4 o2's.2 on the bottom of your mainfold(leftbank,right bank)and 2 behind your cats. I suggest replacing the 2 on the manifold first. You will have to ask the dealership, but I don'
t rememeber if bank 1 is front or back or left or right. IM sure it's the front o2 sensors. Ill check my post from a couple years back and get back w/ you. All my sensores issues went away when I replaced my o2 w/ ford parts.
It's the front sensor on the passenger's side.[/align][/align]Here are some of the possible causes...[/align]
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
