Main bearing studs.
Main bearing studs.
I was wondering if these main bearing studs will fit in a 2001 mustang gt with a remeo block.
http://store.summitracing.com/partde...p;autoview=sku
It says that its for a 1992 to 1998 but on jegs and stuff it doesnt say anything about a year. It just says two bolt two valve modular V8. Anyone know? Also do you know what the torque specs are?
RE: Main bearing studs.
Yes they will work.
use SAE30 oil to lubricate
Main bolts stage1: 30ft-lb
stage2: +90degrees
Romeo Block
side adjusting screws
stage1: 45in-lb
stage2: 90in-lb
side bolts
stage1: 90in-lb
stage2: 16ft-lb
stage2: +90degrees
Romeo Block
stage1: 45in-lb
stage2: 90in-lb
side bolts
stage1: 90in-lb
stage2: 16ft-lb
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
ccdguy
09-19-2015 05:20 PM
