Tri-ax ease of shift?
#22
RE: Tri-ax ease of shift?
great.. i should have gotten that done before the tri-ax. they probably won't do that now that i put an aftermarket shifter on will they? i'm taking the car in wednesday for warranty work on my headlights. stupid condensation.
#23
My Tri-Ax works great. That is, after Ford recalled it and beefed up the transmission with beefier parts. I had the same problem shifting to third that everybody has had, and this fix worked. And BTW, the thousand dollar rebuild was on Ford's nickel. I paid nothing.
#26
ORIGINAL: nanaki
would ford do the TSB on my tranny even though i installed an aftermarket shifter?
Good luck!!
#27
Before I had the tri-ax installed by the dealer, the tranny mechanic told me that if I had a problem with it in the future that it would be covered by the warranty. I got that in writing. So, yeah, work with your dealer and their mechanics. Bottom line though, is to get that Tremec upgraded at Ford's expense.
09-16-2015 07:53 PM
