Octane rating
#21
RE: Octane rating
101 won't help.
I don't understand what you're saying about the timing adjuster? Stock timing is set at 10 degrees....You don't want to advance it anymore than 14 degrees
http://www.mustang50magazine.com/techarticles/33199/
#22
RE: Octane rating
Oh, now i see, so 14 is the safest to go?? What happens if i go over 14? And will i fell a difference on 4 more degrees of timing?? I am done using the 101, dumb idea, i just put 3/4 tank os 87 in to bring the octane numbers down a bit, i guess when i get the timing adjuster on i will use 91 from now on....
ORIGINAL: Dan02GT
101 won't help.
101 won't help.
#23
RE: Octane rating
[quote]ORIGINAL: The02GT
And its not BS, have you ever tried 101 in your car?? Cause I DID notice a bit more power, i am not saying like 10 hp more like 1 or 2 if that. Its def. not worth the money tho and i am not going to use it again till i get my timing adjuster on, and the higher the octane the slower it burns thus creating a bit more power, think about it....
[quote]ORIGINAL: Jakes
Ok so you could actually FEEL a 2 hp increase. The increase may be there but you can't feel a 1-2 hp increase.
