Twin turbos!!
Old 05-21-2008, 08:25 AM
  #31
oxfordgt
oxfordgt's Avatar
Default RE: Twin turbos!!
Hellion does make a twin turbo kit. It just came out and cost around $7K. I emailed them the other day and asked about it and how long it would to take to get it. They replied with "the kit is on backorder now so it will take 1 month. Normaly it will only take a week"
oxfordgt is offline
Old 05-21-2008, 08:35 AM
  #32
devongarver
devongarver's Avatar
oh, its not listed on their site yet though. since they havent emailed me back yet i didnt know that.
devongarver is offline
Old 05-21-2008, 09:32 AM
  #33
oxfordgt
oxfordgt's Avatar
Oh you must have skipped their home page. Its called the hellraiser. Heres a link http://www.hellionpowersystems.com/index.htmlIt can also be used in conjunction with a stock eaton on cobras or kenne bells on gts for a compound system.
oxfordgt is offline
Old 05-21-2008, 09:39 AM
  #34
devongarver
AHA! i see now, i didnt scroll down before i just hit turbo kits and looked there. BTW, i saw a pic of your engine bay in a post the other day but i cant find it now, i wanted to look at it again. What all do you have done to your mustang? It looks really sharp. Im just curious to see what kind of power you are making with what you have since you are n/a(i think) with the sniper tuning. I hope i can hold back and go that route and not get into boost again.
Old 05-21-2008, 09:45 AM
  #35
devongarver
wow! i just watched hellions compund system on the dyno. Over 900 hp. I read an article in MM&FF last night about HP's compund kit on a stock cobra(same setup as hellion) and make only 600+ to the wheels. What gives? cant be that much better than hp that it makes 300hp on the same stock cobra setup. right???
Old 05-21-2008, 10:07 AM
  #36
oxfordgt
oxfordgt's Avatar
I just have a built motor, with a trickflow intake, and lost of aluminum to make it look pretty. Sorry but I have a procharger F1a sitting back home waiting for install. I will be ordering the heads, cams, fuel system, drivetrain over the next few months.
oxfordgt is offline
Old 05-21-2008, 10:09 AM
  #37
devongarver
thats cool, do you have the picture of the engine bay still?
Old 05-21-2008, 10:21 AM
  #38
oxfordgt
oxfordgt's Avatar
Here you go. It looks a bit different now. I removed the pcv system and re ran the the power wire for the battery relocation and moved the catchcan.
oxfordgt is offline
Old 05-21-2008, 10:30 AM
  #39
96GT_PSL
96GT_PSL's Avatar
maybe MM&FF wanted to keep a conservative tune and didnt run that much boost. the hellion stang was running 25 lbs. of boost. thats pretty crazy! if i had the money id get that system! lets see....25,000 for a termi, 8000 for the helion system, lets say about another 20,000 for parts like suspension and forging the bottom end. thats $53,000 for a 900 HP car. sounds good to me!
96GT_PSL is offline
Old 05-21-2008, 10:48 AM
  #40
devongarver
nope mm&ff ran 23 pounds. pretty damn close. they said the supercharger actually limited the top end power, but increase the bottem end power. they also ran the blower by itself, and they took it off then ran the turbos by them selves. the turbos made much much more than the compund system. like 200 hp more if i reme,ber right iwas more than 800.
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
TCStangerv6
10-11-2015 05:57 PM
mdj89
10-08-2015 09:16 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: Twin turbos!!
