UPDATE ON NO START!!!!!!!!!!!!!!!!!!!!! - Page 2 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Reload this Page >
Old 05-21-2008, 05:34 PM
oxfordgt
oxfordgt's Avatar
Default RE: No Spark
THe 21lbs are the pink ones. If those came stock (not sure what year your car is) then you just have to go back thru and check all connections. I am at a loss on this one.
oxfordgt is offline
Old 05-21-2008, 05:36 PM
timeformiller44
yeah i have the pink ones... guess im going to make sure everything plugged in or what not... just doesnt make sense it fired while ALL injectors unplugged then while plugged in.. Poooo
timeformiller44 is offline
Old 05-21-2008, 05:48 PM
oxfordgt
oxfordgt's Avatar
Crank it again with the injectors pluged in then pull a plug. If the plug is wet then you have a problem with the injectors spraying to much.
Check your cam position sensor and cranks sensor.
oxfordgt is offline
Old 05-21-2008, 06:06 PM
jhell00
Possible Scammer
try to cycle you key a few times? turn it on like your starting it but dont start it for 5 seconds and turn it off repeat 3 times. i had the same problem... let me know if it works
jhell00 is offline
Old 05-21-2008, 06:40 PM
timeformiller44
AHHHHHHHHHHHHHHHHHHH
Old 05-21-2008, 06:55 PM
jhell00
Possible Scammer
so did that work for you?
jhell00 is offline
Old 05-21-2008, 07:02 PM
blackstallion666
blackstallion666's Avatar
ok here's a few things to check. Get a test light and check every fuse under the hood and under the dash. if there all good. You can also try unpluging the mass air flow sensor. if this had become dirty or failed it can cause a rich fuel mixture concern fouling the plugs causing it not to start. you can also check the fuel inertia switch and make sure that wasn't tripped for any reason.
blackstallion666 is offline
Old 05-21-2008, 07:18 PM
timeformiller44
no but i am getting fuel....you can smell it heavily when i crank it.. so i know the fuel cutoff isnt the problem bc it will fire with injectors unplugged .. but ill get the maf
Old 05-21-2008, 07:26 PM
jhell00
Possible Scammer
take ur plugs out of your hole and let it sit for about ten min and while its sitting take a lighter to your spark plugs and burn the ends dry then try it all again! but prime your fuel pump by doing the key thing b4 you try starting your car!!! let me know how that one goes!
jhell00 is offline
Old 05-21-2008, 07:27 PM
blackstallion666
just try unpluging it and see what happens
Quick Reply: UPDATE ON NO START!!!!!!!!!!!!!!!!!!!!!
Featured Sponsors
