nitrous
RE: nitrous
ORIGINAL: jwarner0297
depending on you and your abilities the nitrous is good for about 2-3 tenths off your time. I would say if you're a good shifter (assuming you have a 5 speed) roughly 13.3 - 13.5 also depends on your traction
2-3 tenths? a 100 shot can take off up to a whole second. i went from a 13.3- a 12.8 and ran it like a B**** with a worse 60 ft the the n/a run. just get a window switch and a tune and you wil have no worries. expect to see atleast .5 off ur time with a 100 shot
RE: nitrous
highroller02, check this out fyi, http://www.statracing.com/articles/p...trous-kits.asp
02stangguy I was just going off what was on horsepowertv when they added a 100 shot it got them 3 tenths
RE: nitrous
ok first off... 5 speed+4.10s+100 shot... if the car doesnt go 12.50s, sell it, or learn how to drive
2nd whoever explained wet and dry is wrong, wet throw fuel and nitrous into the mix, dry just throws nitrous at it, and the injectors add the extra fuel
what you meant is a nozzle system sprays in the intake tube, plate system is under the plentum, and a direct port has 8 nozzles, one for each intake runner
RE: nitrous
RE: nitrous
ORIGINAL: dimebag
don't forget the tires.
