HELP!!! CAR WONT START!!
RE: HELP!!! CAR WONT START!!
find a few that are the same in the box and switch them around! check were the wire connection in 'POWER DISTRIBUTER BOX' and make sure its getting power going in and then check comming out make sure theres no corrosion on your fuses and they allare tight no loose connections!!
Try hitting your starter witha hammer while someone is in the car trying to start it if it cranks then its the starter if not it could still be the starter but i would keep checking make sure your wires are not rubing on anything.
Its a manual right, just push it and dump the clutch it should start then I had a buddy that did that with his neon for about 2 months he would just park on a hill he was to cheap to buy a starter.
ok latest news, i did switch all the fueses in the boxaround and there is still no power going throught that silenoid wire, for the mean time i cut a piece of rubber of the silenoid wire and touch it with staight power and the car will start, i think iam gonna have to boot leg that wire. if i cant figure out whats going on
hit the unlock button on your remote start, then try it. I have a factory alarm where it will not start if the unlock button is not pushed, then you have 20 seconds or so to start it. Since nothing else has worked.
so it was the solenoid, kinda... sounds like you have to trace it back to the ignition and figure out why you're not getting power to it. could be something in the ignition switch, cause the lights and all that stuff would come on in the accessory position before the ignition part of the switch.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
