plugs wires etc etc`
when do you need to change them?
i just did my fuel filter at 27thousand miles...i do my oil every 6 or 7 with full synthetic...but how often should i do the plugs and wires and other stuff?
ford and the dealer didnt tell me anything i call the dealer and they said nope no special preventive maintanence...so maybe you guys can tell me what i should do and when i should do it?
RE: plugs wires etc etc`
whatever the stock 04 gt comes with...the only mods i have made are the shifter and the cat back exhaust and a drop in airfilter...other then that everything is origonal
ORIGINAL: 2001 GT
I usually didn't unless I noticed a problem such as misfiring. Matters the type of plug also. Are you using a cheap copper plug, or a platinum for example.
ok...but when should i change them? i mean is there a recomended schedual for preventive maintanance or is it the "fix it when it breaks" this is my first ford up until this i owened chevy pickups and they got recomended services to have done at every major mileage like 6 12 18 24 36 48 54 65 72 86 and 100 thousand miles... other then oil lube filter and checking other fluids...
i was just wondering if there is anything i can have done to prevent it from breaking down on the road i hate being stuck on the side of some desolate highway lol..
ORIGINAL: code3GT
If you have the stock plugs in there, you should be good for awhile.
ok thanks..if you can think of any stuff i should do other then the oil change and tire rotations let me know..in the mean time im gonna go beat the service guy over the head with my old exhaust pipes LOL
ORIGINAL: code3GT
If they are the factory platinum's, they are "supposed" to be good for 100,000 miles.
BAHAHAHAHAHAHAH, on that note, my cars 5 years old, (obviously), and when i went to replace my stock Motorcraft platinum plugs, what i pulled out were the biggest rusted out pieces of S**t i have ever seen, corroded like some S**t, my car had 30k miles on it at that time btw. I put in some Bosch Platinum +4s, and they work more that great, swap thos stock p.o.s's out A.S.A.P buddy, u wont regret it.
