need some help
i just added a bbk x-pipe and magnaflow exhaustw/ free flow mufflers to my 03 gt . the car sounds great but has no power what would cause this and how would i fix it . thanks
RE: need some help
DO YOU HAVE MIL ELIMINATORS?
RE: need some help
also the car might not feel as strong because it doesn't have as much backpressure
RE: need some help
i dont have the MILs .
RE: need some help
has u check engine light turned on yet? ethier Mil's or a tuner should fix it
RE: need some help
the check engine light came on for maybe 2 days then went of ( at 1st) then about a week later came up again and the code was for coil packs
RE: need some help
ORIGINAL: wickedstallion the check engine light came on for maybe 2 days then went of ( at 1st) then about a week later came up again and the code was for coil packs |
RE: need some help
im ordering the sct livewire will that do the same as the mil's , i ll take that link ,thanks
RE: need some help
or you have an major exhaust leak.
RE: need some help
ORIGINAL: jmsjags also the car might not feel as strong because it doesn't have as much backpressure |
