Fuel Filter
#21
RE: Fuel Filter
ORIGINAL: jwarner0297
I know however, I don't want to give advice on something and leave anything out so I included disconnecting the negative terminal because "its what the manual says to do" but yeah it is a waste.
ORIGINAL: lilc1511
and disconnecting you battery terminal is jsut a waste of time...
honestly i have NEVER depressurized a fuel system either, but since your likely doing it on the ground and will not be able to quickly move out of the way of the spraying fuel, it might not be a bad idea... i always have a hoist to do it on at work or a creeper at home so it doesn't matter much, it will however still drip like was said above so try to stay out from under it or you will be stinky.
#23
RE: Fuel Filter
thats what happened with me, I depressurized it and i got fuel down my arm, but whatever its not like it was the first time nor the last. I wish I had or could afford a lift
#24
RE: Fuel Filter
ORIGINAL: lilc1511
im a mechanic, i cant afford a lift, my shop can.
