door lock?
door lock?
I went out to my car to unlock the passenger side door and come to find out that the lock is not popping up with the remote. I open the car (driver's side) and hit the lock/unlock switches on both doors and the little **** just budges. Ok, I have not taken off the door panel, for I am throwing a graduation party for my little sister, but am open to ideas before I do so tomorrow.
Could it be the connection to the switch or the actual connection to the rod connected to the lock, or a seperate fuse?
Thank you for any input,
Phil
Phil
RE: door lock?
Ruffcat, my hopes were raised when you mentioned that. I looked underneath the dash and no fuses blown. Actually, looking in the owners manual, my #19 fuse 15A is the door locks.Anybody have a diagram where the clips and screws are located on the door panels to take them off?I have not had the pleasure of removing the door panels yet and would like to do it correctly.
Thank you,
Phil
BTW, the search engine on this website is not showing any results for door panel removal how to.
Thank you,
Phil
RE: door lock?
Ok, the door panel is off, nothing loose or disconnected. The only way the door will "unlock" is if you open the door from the inside to open it. The remote does not unlock the passenger side nor the the passenger unlock/lock buttons. Sensor or loose ground somewhere?? The driver's side is working just fine.
Any suggestions?
Thank you,
Phil
Any suggestions?
Thank you,
Phil
RE: door lock?
i got the same problem, with the remote and manually pressing the unlock button in the car...it could be the actuator thats what i would think, im just too lazy to fix it http://cgi.ebay.com/ebaymotors/99-00...spagenameZWDVW
once in awhile itll unlock...but usually u press it and it tries to go up but doesnt then keeps gettin weaker and weaker
-Pat
-Pat
RE: door lock?
It is most likelythe door lock actuator. They get really weak over time and dont have enough power to push and pull the lock. If the door actuator is mounted like most fords are,You will have to have a punch,hammer,drill,rivet gun and rivets to replace the old one. Take it to a body shop and have them do it if you are not sure....
RE: door lock?
It was the door lock actuator, I went to autozone and picked up a new one. Of course the passenger side is most expensive than the driver's side because that is the side that went out. Funny how that always happens, the part you need is always more expensive than the other side. It was around $70 for the passenger and $50 for the driver's side.
Brian, it was held in by Torx screws, no need for rivets here.
Thank you gentlemen,
Phil
Phil
