two things maybe someone can answer.
RE: two things maybe someone can answer.
ORIGINAL: The02GT
yep def a throw out bearing, mine does it now, and all of my other 5 speed cars did it too, don't worry about it, your clutch will go out b4 the throw out bearing goes in most cases, good luck tho
ORIGINAL: nathansmith50
i had asked a question about this in another forum but never got an answer.
the tuner will allow you to turn it on but will have it in the default off position when you start the car?
traction control is an option so if you didn't get it you probably just have a plug. i think my throw out bearing is going bad but mine squeeks when the clutch is out. neutral or in gear.
ORIGINAL: DuckyGt
you can get a tuner to disable it all the time unless you press it instead of pressing it to turn it off
KingRando
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
