Shifting gear w/o the clutch - Page 2 - MustangForums.com
Old 06-12-2008, 05:49 AM
mhadley4
Default RE: Shifting gear w/o the clutch
yes that is def not a good idea!! as im affiliated with stock car racing we have certain trannys for that such as some jerichos that run 6 grand! but my buddy destroyed his trans doing this so im with the rest of the bunch on saying no!
mhadley4 is offline
Old 06-12-2008, 11:31 AM
Melectrok
Slight modification to this, but how about shifting out of gear without a clutch and then clutching to go into gear. Are there as many issues with this. If you pull out just as you let if it comes right out of gear. It helps for those that have a grind. It's like double clutching but not.
Melectrok is offline
Old 06-12-2008, 02:30 PM
blkthndr03
hmm i didnt know this was bad. i think i might need a new clutch cause the second to third shift is a little rough it always was since i bought it a year ago. what kind of performance clutch would you recomend (brand stage etc.) if my tranny goes my car is still under warranty for two years so ill pay the $100 deductible and get a new one. but ill stop shifting w/o the clutch. i just thought it would be more convenient to slide it into gear. thanks guys
blkthndr03 is offline
Old 06-12-2008, 02:36 PM
1sloblckgt
ORIGINAL: jigz737
thats what i call powershifting
ORIGINAL: blkthndr03
just as the title says is this safe to do i use the clutch to engage first but second through fifth i shift when the rpm's are between 2650-3000 and it slides into gear like butter. any1 else do this????
1sloblckgt is offline
Old 06-12-2008, 02:52 PM
jwarner0297
jwarner0297's Avatar
ORIGINAL: Melectrok
If you are going to do this, why not just depress the clutch the whole time. As people have stated here it has a clutch to be used, and is designed to shift without power being applied to the trans.
jwarner0297 is offline
Old 06-13-2008, 06:47 AM
Eagle2000GT
Eagle2000GT's Avatar
I once had a clutch/pressure plate/something go bad in a neighboring state. The clutch would not disengage. I limped the car (1966 Dodge) home by puttingthe carin neutral when I came to a stop light and shutting of the engine. When the light changed, I started the car in gear (first) and shifted without a clutch by matching rpm. This is not a recommended procedure, but it works.
Eagle2000GT is offline
Old 06-13-2008, 07:13 AM
2000GT4.6
ORIGINAL: jigz737
so in other words, you don't know what powershifting is?
Also, this "method" will not help you if your clutch goes out. If your clutch is "out" the engine is no longer connected to the transmission... so your car won't move.
shifting without the clutch = FTL.
2000GT4.6 is offline
Old 06-13-2008, 09:21 AM
Eagle2000GT
+1 I once ripped a clutch pad to threads. You pretty much go nowhere fast.
Old 06-13-2008, 02:23 PM
93cobra22
just use the clutch its there for a reason
93cobra22 is offline
Old 06-13-2008, 08:50 PM
mikemc04gt
mikemc04gt's Avatar
I just feather mine for gear changes. I don't go to the floor, about 1/2 pedal makes shifting easier and is better for the tranny han not using the clutch. Shifting doen't put much if anywear on the clutch, its starting from a dead stop and especially trying to hold the car on a grade that eats clutches.
mikemc04gt is offline
6bangr
02-15-2016 08:40 AM
uedlose
The Racers Bench
10-01-2015 09:31 PM
mrappe
09-26-2015 11:16 AM
ccdguy
09-19-2015 06:20 PM
Quick Reply: Shifting gear w/o the clutch
Featured Sponsors
