Traction Control - 2000 GT - MustangForums.com
Old 06-12-2008, 02:28 PM   #1
newb2000GT
newb2000GT's Avatar
Default Traction Control - 2000 GT
My traction control light is no longer lit on my button in a 2000 GT.
Is there a problem with the traction control or is it simply an indicator light? I haven't checked the fuses yet but I will do that soon. The weather is good right now but if it gets cold or wet I will have issues and I don't need traction control kicking in if my tires break free.
Any thoughts?
TIA!
[edit]
I found this in the online owner's manual:
"If a system fault is detected the OFF indicator lamp on the traction control switch will be illuminated and your vehicle should be serviced."
The light does not come on whether it is pressed or not so I'm assuming this means a fuse possibly.
newb2000GT is offline   Reply With Quote
Old 06-12-2008, 02:39 PM   #2
FoMoCo99
Default RE: Traction Control - 2000 GT
I would definately check the fuses first. I know that the fuse for the traction control also operates a few of your dash lights, like the service engine soon light and things like that. Just turn your key on and make sure it looks like all those lights are coming on, if not chances are it is the fuse. I would just try to turnthe traction controloff and then bring it off to see if the traction control kicked in. If anyone else knows a way to just bypass the traction control without pulling the fuse so you lose the other things, I would be happy to know how it is done.
FoMoCo99 is offline   Reply With Quote
Old 06-12-2008, 02:40 PM   #3
jwarner0297
jwarner0297's Avatar
if you give it WOT does your car spin and still rev? If so then it is probably just the light or power getting to the light
jwarner0297 is offline   Reply With Quote
Old 06-12-2008, 02:45 PM   #4
newb2000GT
newb2000GT's Avatar
Quote:
ORIGINAL: jwarner0297
I have 285's and subframe connectors so I have really good traction. If I stand on it, I go.
If I rev it and dump the clutch I can easily break them loose but I do not want to do that because if traction control kicks in and cuts fuel while I am in boost (which I will be if I break them loose) that would be really bad.
Old 06-12-2008, 03:51 PM   #5
cliffyk
TECH SAVANT
cliffyk's Avatar
The fuse the powers the t/c on-off LED is a 15A fuse in position 5 (front left corner of the fuse block). If it's blown the LED cannot light, and you will not be able to turn off the t/c as it is also the source for the 12V signal used to tell the instrument cluster electronics (which in turn siganls the ABS module) to turn on the traction control.[/align][/align]
cliffyk is offline   Reply With Quote
Old 06-13-2008, 11:03 AM   #6
newb2000GT
newb2000GT's Avatar
Well, it was wet out today and I was spinning quite a bit. Traction control was in fact off (spun just fine and no TC activation light on the dash) but the light was not lit. I guess it could be that the LED is burnt out. My other idiot lights believed to be on the same fuse as the TC light are working fine so it's probably not a fuse. I thought it could be a wire connection issue but based on what cliff says above, that likely isn't it. I'll pull the button out this weekend and figure out what the deal is. Thaks for the help guys.
Old 06-13-2008, 12:16 PM   #7
cliffyk
TECH SAVANT
cliffyk's Avatar
Here's the wiring diagram for the t/c switch:
That lower module with the SCP+ and SCP- terminals is the ABS controller.
If the t/c is off, after starting the car (and your not pressing the button), then it may be that the normally open PB switch is shorted or stuck closed. Another possibility of course is that it's turned off in the tune and the LED is lit for some reason.
Check the connector at the switch for bent/shorted pins, and see if there's +12V at pin 1 (key in RUN). You could aslo connect a 1-1/2V battery across pins 6 and 4 of the switch (+ to pin 6) to see if the LED is good.
If there's power at pin 1, and the LED tests OK with a battery, then the problem must be in the instrument cluster's electronics.
Old 06-13-2008, 12:27 PM   #8
cliffyk
TECH SAVANT
cliffyk's Avatar
Quote:
ORIGINAL: newb2000GT
I just reread your posting, the fuse is dedicated to the t/c (it feeds one of the 4 power inputs to the cluster, however I suspect within the cluster it is also dedicated to t/c functions), if you have not checked do that first...
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 11 03-12-2018 04:16 PM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 06:23 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 04:55 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 11:13 AM
V6 Project Problems ThatJuanStang V6 (1994-2004) Mustangs 4 09-25-2015 08:01 AM
04, 2000, 2003, abs, bypass, connect, control, engine, fuse, gt, light, mustang, problem, service, switch, traction
Featured Sponsors
