no power to the fuel pump
hey yall, recently my fuel pump stopped working out of nowhere, i got my test light and checked all of the fuses both under the hood and under the dash but to no avail. so i went to see if the impact sensor in the trunk was set off, but no luck there either. so i checked the power while my dad tried to start it, but there is no power at all. can yall help me out plz
RE: no power to the fuel pump
Have your dad turn the key to "On" not start while you sit at the back of the car near the Fuel Door. Do you hear the Fuel Pump engageing? If not, chances are it's burnt out and needs to be replaced. It's not uncommon for the Fuel Pump on our cars to die, mine went out at 88k long and reliable miles.
Location: Where gunshots are more common than birds chirping
Go to the CCM and test a light blue/orange wire. Thats the wire that activates the relay. Green/black wire coming out of pin 11 of the CCM is your fuel pump power wire. Check that. If all else fails, make sure you have a good ground at all locations.
uberstang1
09-20-2015 06:42 PM
