Misfire or Clutch-Slip??
Old 06-27-2008, 09:22 PM
moreyt25
moreyt25's Avatar
Default Misfire or Clutch-Slip??
Have a 2001 GT with approx. 96k miles. Cant really confirm what feels like a misfire or maybe a clutch-slip. It mainly happens after completing a shift into a higher gear or when down shifting to a lower gear and the engine is under a load. I started off with cleaning the MAF, checking the operation of the EGR valve, and changing the fuel filter (which was quite dirty by the way)..Fuel pressure is lingers @ around 35-40 psi at idle... Pulled out the scanner and there are no pending codes in the computer...
The clutch has never been replaced and the plugs and one coil pack were replaced a while back when i had a definite misfire. So.... when it acts up, its a definite "miss", but not (if that makes sense) maybe like the car is pulling, but momentarily stops pulling is more like it... Was curious to see if anyone else has had this problem, or can point me in a direction I havent already explored... Any help would be appreciated. Oh, and at idle there is a sporadic "putt-putt" sound coming from the exhaust. Also have checked the temp on both heads and manifolds and the temps are consistant so I dont really think a backed up cat could be an issue.
moreyt25 is offline
Urambo Tauro
06-10-2016 03:28 AM
Omgitsa88Stang
10-05-2015 07:33 AM
bconboy
09-21-2015 12:52 PM
chrisc
02-10-2006 10:16 PM
ghoste
09-07-2005 11:42 AM
Quick Reply: Misfire or Clutch-Slip??
