A fuse out or bigger problem? help!
I got out of a movie and started my car, turned my lights on then noticed my guages didnt light up, fog lights didnt come on, tail lamps didnt come on, etc. Any ideas what fuse it is or what it could be? I've checked all of them that made sense to me. It's off that all the things arent working instead of one specific thing.
When I brake the lamps work, its just while my headlights are on that they do not light dimly like they should.
RE: A fuse out or bigger problem? help!
I had a similar problem. Recently my brakelights or blinkers would not work.. kept blowing the fure after i replaced it like 5 times.. they would work then after i started driving it would blow again..
finally it came down to crawling under the dash, i guess over the years the clutch pedal wore through the tape and rubber around that certain wire so the clutch pedal(metal part) would touch the wire and blow the fuse.. so we retaped it.
give that a check, otherwise i have no clue my man. I HATE wiring and electrical problems lol..
