Transmission HELP
Transmission HELP
I have a 96 GT automatic and after a bit of speeding and hittin a HUGE hole in the process, when i put the car in drive it shifts from the first gear(at about 30MPH) at 3500 RPM. that is extremely to high and its sounds like im doing 100 which is bound to get me a ticket and im sure im eatting gas. what is the problem? HELP PLEASE!
RE: Transmission HELP
Is it slipping? If so, you need to check/replace your transmission fluids. I guess that's what your trying to describe? Possible tranny bout to **** out on you, too. I had this happen to my silverado and the clutch plates fell to the bottom of the tranny after a week of it slipping...
You should have your transmission serviced, i.e. bleed the transmission and have the fliud replace. I had a Dodge 1500 that was doing the same thing and i had the transmission serviced and the problem disappeared. It cost me about 120 bucks but that was cheaper than a new tranny.
