Insrument Light
Insrument Light
Help! Sometimes i get this dash light that comes on when i start my car it is a yellow battery with a water line at the top and a fan in the middle. usually it comes on when i first start my car in the morning and it stays on but then all day after that it doesnt come on. But at the start of a new day it does it again. Thanks in advance
RE: Insrument Light
Well you should first try resetting the computer by disconnecting the battery and then reconnecting it after about 5 min. If that doesn't work you need to keep an eye on your coolant level and temperature gauge cause you could have some sort of a leak or a cracked intake manifold like I had...
RE: Insrument Light
haha, what are the odds! I had the same thing today!
have u done any work with your coolant? uplugged the hose for some reason? if so, you must bleed the system, that will clear it up...i bled it for like 45 seconds and it went right away.. if u need to know where the bleed screws are lemme kno and ill get u a pic.
RE: Insrument Light
well, here's the two pics...ill they're easy to see....
they are two black tops right on the bottom of the CAI and on the top of the CAI...if u need, ill change them in paint.
obselite.tripod.com/pictures
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
